tasonthego1
Jul 22, 2025Follower
It keeps telling me there is no internet and won’t let me connect with the anywhere access
I have this same issue. It keeps telling me there is no internet and won’t let me connect with the anywhere access in the Orbi app. I’ve done a reboot, turned the web protection off in the Netgear VPN, but it still won’t let me do the anywhere access. And it’s not broadcasting WI-FI signal to my home security system. It can’t do a firmware check either.
Any progress on this?
Orbi app updated today for Apple. 18th for Android:
New Orbi App Versions and Updates | NETGEAR Communities
Are there devices which ARE connected to this Orbi over WiFi?
(i.e. the Orbi IS broadcasting WiFi and other devices can select this WiFi SSID, enter the password, and connect?)
Can a web browser on a device connected to the Orbi WiFi open the Orbi web management page?
(typically http://orbilogin.net )Mention of Netgear VPN would seem to indicate that Bitdefender Armor is enabled on this system, correct?
What Orbi model system do you have?
What mobile platform do you have Orbi app installed on?
Can you access the system at 192.168.1.1 using a PC and web browser?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Can you try a factory reset on the system and setup from scratch using a PC and web browser and walk thru the routers setup wizard. Then after that completes, try accessing the system using Orbi app?
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
or Orbi Systems Manual Factory Reset Process | NETGEAR Communities
Then:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
