veacomp's avatar
veacomp
Orbi app not showing offline devices.
I recently purchased an Orbi 772 system and noticed with the latest app update that the Devices screen no longer shows offline devices so I can delete them. They also don't show in the web portal but that has always been the case. Looks like they rolled out a new UI in the device experience in the App. Wondering if there is another way to view offline devices.
Thanks much!
  • CrimpOn's avatar
    CrimpOn
    Does the web portal have the Security Menu, Access Control. On older Orbi routers, there are tables of devices that are not connected. If Access Control is enabled, those tables can be cleared.
