Grahame2026
Jan 29, 2026Aspirant
Orbi App Settings
My Orbi 13 has stopped connecting to my Hot Tub am iAqua app. I am told that the app will only connect to if the unit is set at 2.4 or 2.5 Gigs, but I can't locate where in the app I can check or adj...
Grahame2026
Where do I locate the RBR and the LoT network?
Jan 30, 2026Guru - Experienced User
If it's there, try under the Basic/Wireless tab on the RBRs web page.
If it's not there, you may need to turn OFF all RBS, reduce the power on the RBR from 100% to 25% long enough for your mobile device to connect at 2.4Ghz and attempt to get your IoT device to connect then.
Grahame2026 wrote:Where do I locate the RBR and the LoT network?
