Grahame2026
Jan 29, 2026Aspirant
Orbi App Settings
My Orbi 13 has stopped connecting to my Hot Tub am iAqua app. I am told that the app will only connect to if the unit is set at 2.4 or 2.5 Gigs, but I can't locate where in the app I can check or adj...
Jan 29, 2026Guru - Experienced User
Check with the Hot Tub apps Mfr for help and information regarding there app and product.
