May 05, 2020Guru - Experienced User
Alternative to Armor and Circle on Orbi AX
Since Armor or Circle isn't fully supported on Orbi AX as of yet, user may want to review this:
"To protect family/kids from malicious Internet content, DNS filtering is simplest defense and it's free. There are quite a few of free/paid DNS filtering services out there, but I find that free DNS filtering service is sufficient for me.
My two favorite free services are Cloudflare Gateway and CleanBrowsing DNS Filters.
I've tried both services and I found that CleanBrowsing/Adult Filter is best and simplest to setup. However, if you want a nice DNS report, flexibilty (what to block), and speed, stick with CloudFlare Gateway. The setup process is similar for both, just point your router/Orbi DNS servers to their IP addresses. That's it!
Good luck!"
- 60sguyAspirant
Can't you plug a Circle Home Plus into the Orbi AX6000 RBR (router) to get Circle to work? I konw it's not built in but it seems from the Circle website that Orbis are compatible?
Asking as I just ordered my Orbi AX system and was planning to do this. I really rely on Circle for my kids so if this won't work please LMK, but I'm assming it will? (I know you need to subscribe to Circle Home Plus but I'm fine with that.)
Seems like that is a external device. Something to ask the Mfr about to see if thats possible.
60sguy wrote:Can't you plug a Circle Home Plus into the Orbi AX6000 RBR (router) to get Circle to work? I konw it's not built in but it seems from the Circle website that Orbis are compatible?
- tarcvfGuide
I have been using Disney Circle Home Plus with my RBK853, it works fine but you have enable Router Compatibility Mode ON
Does not work if Compatibility Mode is OFF
Also in my experience as soon as they launch Circle for Orbi RBK853, you can turn off Compatibility Mode OFF and it should work without any issue. I have been using Circle Home Plus for a while now, and it works great with kids at home.
Thank you for letting us know. Glad that solution is working until if or when NG decides to release Circle for Orbi AX.
Enjoy.
tarcvf wrote:I have been using Disney Circle Home Plus with my RBK853, it works fine but you have enable Router Compatibility Mode ON
CleanBrowsing even has a guide for Orbi - How to change DNS on a NetGear Orbi Router.
Looks like Armor is now in FW for Orbi 850 series:
