sureshsumithra
Aug 17, 2020Aspirant
AX6000 WiFi can be connected with Huwai CPE pro Wifi 6 Router
Orbi AX6000 WiFi can be connected with Huwai CPE pro Wifi 6 Router
Are you asking if it can?
If so, yes you can. It can cause a double nat with 2 routers running in router mode. But there's ways around that.
Yes but not generally recommended. You can do double NAT if you use the host routers DMZ.
Or configure the Orbi base router for AP mode, leaving the host router has your main router and disable the main routers wifi radios.
sureshsumithra wrote:Orbi AX6000 WiFi can be connected with Huwai CPE pro Wifi 6 Router
- sureshsumithraAspirantHuawei CPE ROUTER COMES WITH SIM card slot.
IF I CONNECT THE LAN connection of HUWAI CPE to LAN connection of AX6000wifi router.
It will work in this way?- FURRYe38Guru - Experienced User
Yes.
So the Huwei is a LTE cell phone wifi router?
If this router has a DMZ, please use this feature if you use the RBR in router mode. If not, then you'll need to configure the RBR for AP mode.
