SilkyJohnson
Aug 10, 2023Aspirant
CBR750 and fiber
I have a CBR750 and we are about to get fiber. What do I have to do to make my Orbi system work with fiber. I want my Satellites to function with whatever change needs to be made to the CBR750 modem/router. Please advise.
the CBR is a Cable ISP connecting system. It wont work with Fiber. Only think you can do is to configure a Faux AP mode on the CBR and then connect one of it's LAN ports to a host router.
- SilkyJohnsonAspirant
I have a CBR 750 modem. We are about to get fiber. I want to know if I purchase a RBS750 router will my current satellites work with the RBS 750? Do I just need to get a RBS750 router to make my current set up function with fiber? Thanks.
Do you mean getting a RBR750>?
Yes. That's exactly what I meant. Will my current satellites work with an RBR750?
- KevinLiTNETGEAR Moderator
Hello SilkyJohnson ,
Welcome to the NETGEAR Community!
The RBR750, RBR840, and RBR850 are all compatible with your current RBS750 and can be used with your fiber configuration.
Best,
Kevin
Community Team
