BenUK83's avatar
BenUK83
Follower
Feb 17, 2022
Connect to Satellite over Router
ORBI RBK752
Hi, I’m having trouble where a device will always take preference connecting to the router if available over connecting to the satellite. Even if the satellite has a stronger signal. Does anyone know of a way how I can force the device to choose the satellite in times when it will have a better connection?
Thanks
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Thank you
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    It's up to devices to pick and choose where they connect to based on distance, device design and noise and conditionss of the system.
    BenUK83 wrote:
    ORBI RBK752
    Thanks
