wefjeber's avatar
wefjeber
COSTCO RBR750 2 Satellites slow wired speeds
I just bought an OBI RBR750 from Costco with 2 Satellites.    My home has Cox Gigablast (1,000MB/S) and  is wired so each Satellite has the wired backhaul.  In my office,  I use Satellite 1's additional port to go through a TP link 5 gigaport switch.   My problem is the connected devices (a PC and Xbox) are only getting 94MB/S!!!     If I bypass the ORBI and connect each device directly to the cable modem they are getting 800MB/S+.    I have tested by going through the switch and w/o switch direct  to the devices and the switch is not the problem.
Just to add a little more to the picture, I have an IMAC right next to the ORBI router and it consistently gets over 300MB/S wireless.   Why is the wired component to the satellite so slow?
Problem 2:  I had used the app to test the internet speed to the ORBI router and it was always 700MB/S+ but now all of a sudden, every time I try and test the speed through the ORBI app  I get a 'connection failed' error and hitting 'try again' alwyas produces the same result.
My firmware is 3.2.16.6 and appears to be the most up to date.    I am not loving my ORBI right now!!!!!  Can anyone shed some light?
