brandobot
Feb 02, 2022Guide
Device not showing up under "Attached Device" in console
On my RBR850, I connected a device via wifi. On the device itself (while connected through bluetooth), I can see my device has an IP of 10.0.0.83. From another device on my network, I can ping this device.
However, If I go to "Attached Devices", I am unable to find this device. How can I get it to show up?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What device are you referring too?
- Firmware 4.6.3.16
Modem is Arris bgw210.
The device connected is a Bobcat 300 Helium miner.- FURRYe38Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI recommend option #2.
What browser are you using?
Does the Orbi app experience same thing with this device not appearing?
Is the device connecting to the RBR or RBS that you can tell? Look at the RBS web page as well.
Might review this as well:
- ekhalilMasterDo you have SPC (Smart Parental Control) activated?
When the new SPC is active the way the Orbi app handles attached list and the list’s format is different.
I noticed the same issue with devices not showing in the attached list (of online devices) and the device will show as not online although the device is online!. What I do to get the device again is to “remove the device” then with the next refresh it will start to show correctly in the list.
