MrFendster
Jul 19, 2021Aspirant
Device won't connect - AX6000 RBR850 FW V3.2.18.1
Trying to reconnect a Netgear WNCE2001 wifi adapter to my Orbi. It has previously been connected now it doesn't show up on the connected devices. A notification is generated that a new device has been connected but there is no device indicated on the app ... clicking on the notification takes me to a page to extend the Armor subscription but that is subject of another post.
I have rebooted the Orbi and the modem numerous times in the recommended order and yet no positive result.
As I am having similar issues maintaining connection of my Google Hub to the Orbi satellite, I am begining to regret the purchase of this +$1k product.
Ah Hah ! Excellent. I'll reconfigure an old Netgear N300 router as a bridge.
Thank you so much for your persistence with my problem ;-)
Try disabling AX mode on the RBR...
- MrFendsterAspirant
Thanks Furry, I've searched the router and can't find any switch for AX mode ... can you point me in the right direction, please ?
Basic Tab/Wireless settings. Uncheck the check box next to 2.4Ghz...
