Bobkc
Aug 18, 2021Star
Drop in Download Speed - RBR750 with Satellite
I have been using the using the Orbi RBR750 for 8 months now and 30 days ago the download speed dropped from 940mbs to 610mbs. Have noticed the satellite has been indicating that it is receiving periodic weak reception during this time period when the speed dropped. Upload speed has been consistent/unchanged at 41/42mbs. Verified that the most current firmware is installed.
When ethernet connected directly into the Orbi, the desktop will pull the 940mbs. When on wireless, it drops to 610mbs. Desktop is literally 1 foot away from the main Orbi so there is no interference. I have tried a power down and a factory reset and it has had no change on the situation. I have powered down the satellite as well as the modem with no change.
Have tried various speedtests providers and using the Orbi app and still the same results. The entire environment uses Apple devices. Orbi is ethernet connected to a Netgear CM1150.
Ideas???
NG is aware of problems of recent FW versions and is working on it.
Please contact them directly to let them know what your seeing.
Hopefully will be fixed in next FW update. We don't know when that will be so be patient.
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
- LJ3000GuideI am having the same issue and was directed to this site.
CBR750 — Orbi WiFi 6 DOCSIS 3.1 Mesh WiFi Cable Modem Router
Firmware version V4.6.3.6
App version 2.11.0.11
In last two days, my Download speed dropped from between 1200-1400 to 500-600. Had this model since March 2021 and first time a download speed drop has persisted more than a few hours. Tried calling support and they provided basic advice and had me change a couple settings and said everything else looked okay and to give it 24 hours. The drop seems to have started happening right after I installed the last firmware update. I called ISP (xfinity) and they said everything is fine on their end and they are sending 1g speeds. I paid $1k for the modem router combo plus two satellites and netgear tech on the phone says I need to pay a subscription if I need advanced help. I am so disappointed. Has anyone else experienced a slow down after latest firmware update?I too contacted Xfinity and they told me all was good on their end which when I am ethernet connected to the modem, I can pull the 940mbs. Wireless it drops to 640mbs. I concur with your comments about disappointment and have passed the 90 day free support. Can't rationalize why I should pay for support on a Orbi issue that they are aware of. Would think this would at the top of the priority list. Doesn't make a lot of sense.
What devices are you using to speed test with?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Armor enabled?What CTS values are currently set? Under Advanced Tab/Advanced Settings/Wireless Settings
Try setting 2347 on CTS
- Blanca_ONETGEAR Employee Retired
- CdhappzAspirantI have the same issue. Had consistent speeds of 1300-1400 mbps download and 41 mbps upload. Now after new firmware 500-600 mbps download still 41 mbps upload. Testing speed directly in router login because app is useless as it crashes and is unusable
Please open a support ticked with NG support and let them know what your experiencing. Can reference this forum thread as well.
Thank you.
Cdhappz wrote:
I have the same issue. Had consistent speeds of 1300-1400 mbps download and 41 mbps upload. Now after new firmware 500-600 mbps download still 41 mbps upload. Testing speed directly in router login because app is useless as it crashes and is unusableI have searched the Netgear site in order to find out where I can file a support ticket. I am out of the 90 warranty and don't want to purchase a support plan to report a Netgear issue. What am I missing? Can someone send a link that I can use to report the problem?
