goodew
Aug 01, 2022Aspirant
Expansion Network rbk852, IOS
Hi
I have a network RBK852, 1 router, 1 satellite.
I have a "almost dead" corner in my living room, hardly WifFi signal.
Q1: Is itl possible to expand the network with an extra satellite?
Q2 If necessary, can I put the Satellite on a UTP Cable (Cat 5e) to kill the dead spot?
Ya add a RBS via ethernet connection in this area of the home for coverage:
goodew wrote:
Hi
Q1: Is itl possible to expand the network with an extra satellite? Yes
Q2 If necessary, can I put the Satellite on a UTP Cable (Cat 5e) to kill the dead spot? Yes. CAT6 is recommended.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡 - goodewAspirant
Hi
Additional info
ThanksWhat Firmware version is currently loaded?
V4.6.3.16_2.0.51 (not able to update)
Mfr: Compal Broadband Networks Inc.
Model: CH7465LG-ZG (Not Sure, is only identification on Modem)
S/N. DDAP53222980What is the size of your home? Sq Ft?
Groundfloor 100 m2 ~ 1075 Sq Ft
First floor 60 m2 ~ 646 Sq FtWhat is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS
Router (Living Room, GF) and Satellite (Study, 1st Fl, ~8 meter from Router, works well) are located at the front of our house.
The dead corner is at the back of our house ~ 12 meter away from the router, behind two half stone brick walls.Wim- FURRYe38Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first if you haven't already.
Stone brick walls will be problematic for any wifi signals
- goodewAspirant
Thanks!
I have option #2 already operational from the begining; all Wifi bands shut off.Orbi Router is the only Router.
This causes the weak/dead spot in my house...checked it with NetSpot best Signal ~ -85 / -90 dB
My Apple TV doesn't work properly due to bad signal
So,.... best solution?
Install extra Satellite? possible with cable?
Just install switch and connect all devices with cable? direct cable to modem available
