PhilDaNoob
Feb 05, 2024Aspirant
Force Plystation Portal onto 5ghz band.
Hi everyone,
I have a Netgear Orbi RBR850. At the weekend I purchased a Sony PlayStation Portal. The Portal is suppose to run on a 5Ghz band. How do I force the Portal onto the Orbi’s 5ghz band?
Many thanks!
Many thanks!
PhilDaNoob wrote:
The Portal is suppose to run on a 5Ghz band. How do I force the Portal onto the Orbi’s 5ghz band?You'll have to ask the people who made the portal.
By design the Orbi broadcasts both 2.4 and 5 GHz. it is up to your devices to connect.
If the device doesn't work with 2.4 GHz, it won't see it.
- PhilDaNoobAspirantThank you for your reply.
The PlayStation Portal can hop onto 2Ghz and 5Ghz bands. However, it’s recommended to run it on the faster 5Ghz band only.
Is there a way to achieve this on the Orbi?
Previous routers I have owned (by other brands) had the ability to assign a device to either the 2Ghz or 5ghz or both bands.- michaelkenwardGuru - Experienced User
Is there a way to achieve this on the Orbi?Not with the original Orbi Mesh routers.
Some newer devices do have that feature, my MR93 Mesh, for example, but I see no sign that this is possible on the RBR850.
The PlayStation Portal can hop onto 2Ghz and 5Ghz bands. However, it’s recommended to run it on the faster 5Ghz band only.Does that have a way to say "Use only 5GHz"? On things like mobile phones it is down to the phone to pick the best signal.
What FW is loaded on the RBR?
Any RBS deployed? If so, how many?
What channel configurations are currently set on the router?
On new FW, there is options to get devices ON 5Ghz on Orbi 8 series systems.
However it is up to client device to connect to either frequency based on design and support. Be sure your device supports 5Ghz. Most 5Ghz supporting devices usually pick 5Ghz first thing when connected if 5Ghz signal is present. Could fall back to 2.4Ghz if something is not working right or not configured right.
PhilDaNoob wrote:
Hi everyone,
Many thanks! - CrimpOnGuru - Experienced User
PhilDaNoob wrote:
Hi everyone,
Many thanks!As others have commented, the Orbi system does not provide a mechanism to force a product to connect at 5G.
In the discussion, I did not see information regarding what connection it has. Is it connecting at 2.4G or 5G?
One can setup the IoT network for 5Ghz only broadcast on v7 FW I believe.
