Pkkz124
May 11, 2024Aspirant
Help w Orbi RBR750 internet connectivity issues
Having trouble with my Orbi RBR750 purchased in 2021. Recently had my router constantly turning ‘purple’ and not connecting to my internet. I reboot the system and it works for a few hours but then does it again, is this something wrong w the router? Other than constant rebooting what can I do to fix? I checked and my firmware is up to date. Thanks for the help! It appears to be out of warranty?
Yes, the hardware warranty for Orbi products is one year. A 2021 purchase is no longer covered.
Netgear released an optional firmware update for the 750 product, which can be found here:
https://kb.netgear.com/000066099/RBR750-RBS750-Firmware-Version-7-2-6-31
To manually update the firmware, follow these instructions:
Usually if its purple/magenta, it can't connect to the internet.
What modem/gateway is it connected to?
When it turns magenta, are you still able to connect to the orbi and view its GUI?
What does it show under the internet connection?
- Pkkz124Aspirant
I've had to constantly reset the router when it turns Magenta. It then works for a few hours, but then doesn't work again. I basically have to constant reset the ORBI Router. definitely something with the router and not my modem or internet which is working fine.
Which didn't answer a single question I asked and specifically avoided them.
Troubleshooting isn't a "click this and its fixed". Its figuring out a users setup to see what could potentially be causing the issue. I've got a 750 series running on spectrum and its been rock solid in its stock setup. But we know nothing about your setup
