AG_2022
Apr 20, 2022Aspirant
HELP with Orbi Mesh WiFi System
Hi I have the
NETGEAR Orbi Mesh WiFi System (RBK752) | WiFi 6 Mesh Router with 1 Satellite Extender |WiFi Mesh Whole Home
and my supplier is Virgin Media with a Hub 4. I thought I had followed everything to the letter, including enabling modem mode on the Hub 4 but can't get it to connect to the internet. Can I ask for the idiots guide on how I set this up please? Thanks, Amanda
I always seem to see people having issues with the virgin hubs.
What many do is leave the virgin hub in router mode, disable its wifi, and then put the netgears IP address into the virgin hub's DMZ.
If that doesn't work, you could simple leave the virgin hub in router mode, disable its wifi, and put the netgear in access point mode.
Sadly, you do lose some features on the netgear if you do that.
