liamscor
Jun 09, 2025Luminary
I found that disabling all logging and then performing a full power cycle of my 963 system
I found that disabling all logging and then performing a full power cycle of my 963 system—a step I came across in the post linked below (which discusses BE systems)—resulted in a significant performance improvement in my setup, allowing me to have a mucher longer uptime before needing to reboot for system stability.
I was also encountering a connectivity issue with certain devices after 5–8 days, which required a full system reboot to resolve. After disabling logging, that issue seems to have been resolved as well. I thought this might be helpful to share in case others are facing similar problems.
- liamscorLuminary
Just an update on this, I have found that if you have netgear armor enabled, there then seems to be some issue related to the logging, I have now factory reset and setup from scratch via the via web gui and not used the orbi app, and haven't had to disable any logging.
Only ones I have enabled on my 963 system:
Include in Log Connections to the Web-based interface of this Router Router operation (startup, get time etc) Known DoS attacks and Port Scans Wireless access I also have SIP ALG enabled as well. Normally disabled by default. Was mentioned years ago that enabling this helped as well.
- donawaltMentor - Experienced User
FYI I read SIP ALG (Application Layer Gateway) is a helper service meant for old VoIP systems — it inspects and modifies SIP (Session Initiation Protocol) packets for voice calls.
On many modern routers, SIP ALG causes more harm than good, breaking VoIP calls, Ring doorbells, or Teams/Zoom sessions. Disabled for me, haven't seen any issues.
donawalt wrote:
SIP ALG (Application Layer Gateway) is a helper service ... On many modern routers
Yes. It is not "modern routers don't need them", it is instead that VOIP providers have built infrastructure for NAT traversal into their clouds.
Another aspect is that the SIP packets can't be modified when the signaling channel is encrypted (TLS in the case of SIP), and the best practice today is to encrypt both the signaling and the media.
So modern VOIP phones (and other SIP clients) generally don't need the router ALG. And it can sometimes get in the way.
donawalt wrote:
Disabled for me
And for me. I think in general people should disable it, unless they discover that they need it.
- liamscorLuminary
Thanks will try this when I get round to it.
