jonseff
Mar 07, 2026Tutor
Level Connect hub keeps disconnecting from RBR750 network
I have an RBR750 and three satellites that make up my mesh network. I recently added a Level Connect hub so I can actually do anything with my lock when out of Bluetooth range. Setup works fine but t...
Mar 08, 2026Guru - Experienced User
Did you manually update the RBS first then RBR lastly using there web page to update to FW, then perform a factory reset on the entire system to see of the QV changed? Was reported by those effect with this QV issue that this was fixed in latest version of FW.
jonseff wrote:[Update] Manually updated firmware on the two satellites, but they're still showing model as RBS750QV with an "update failed" status, even though they're now running the latest. Level Connect working for now, but will check again tomorrow.
jonseff
Mar 08, 2026Tutor
RBR and one of the RBS satellites were already running latest firmware, so I just did the two other RBS one at a time. No factory reset, just rebooted the system through the web interface.
- FURRYe38Mar 08, 2026Guru - Experienced User
RBS needs to be updated first before the RBR, then RBR lastly. Factory reset the system then set up from scratch. QV issue should be resolved for each RBS:
Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
Orbi Systems Manual Factory Reset Process | NETGEAR Communities
