bestsongever99
Aug 05, 2021Follower
Missing confirm button when manually updating firmware.
When trying to manually update my firmware to downgrade? Since "updating" to new version V4.6.3.7_2.0.49 I have been having issues connecting to Wi-Fi, dropping connections when streaming Plex or any ...
Aug 06, 2021Guru - Experienced User
Downgrading from v4 to v3 is not supported.
Try a factory reset on the RBR and RBS and setup from scratch. If your problems continue, please open a support ticket with NG.
bestsongever99 wrote:
When trying to manually update my firmware to downgrade? Since "updating" to new version V4.6.3.7_2.0.49 I have been having issues connecting to Wi-Fi, dropping connections when streaming Plex or any type of service at least twice every 10 minutes sometimes more. But when I tried to manually update my firmware I setup the RBS750 just fine but then after I try to do the router and apparently they remove the yes/confirm button so I'm stuck with this update that has been horrible right after I downloaded it. Sometimes certain devices can connect to the Wi-Fi but it can't connect to the internet even though it's available but if I open a guest Network they can log in just fine. Does anybody have any ideas for me please? Also I have the RBR75 Orbit AX4200 Tri-band wiFi Router but of course it's missing from their model list.
