Imulji's avatar
Imulji
Guide
Aug 09, 2021
Moving from RBK23 to RBK753 and having issues!
Hi there
Moving from my old RBK23 (1 router and 2 satellites hardwired) system to a new RBK753 ( 1 router and 2 satellites hardwired) system and having massive issues with the move over.
I disconnected the entire RBK23 system and replaced with the RBK753 system exactly as I had.
Ran the Orbi app and setup new system. Everything works until checking internet connection and says not detected. I’ve tried different network cables and that isn’t working. I’ve tried to only hardwired the modem (bridged) to the router and nothing else (switch which connects to the satellite) and this doesn’t work.
Nothing seems to work!
I’ve replaced the RBK753 and having the same issue so there’s obviously something wrong with my system but I can’t figure it out. The old RBK23 system works great with the original setup.
Any thoughts?
Thanks
  • FURRYe38's avatar
    Does your modem or ISP use PPPoE or DHCP for connections services? Something to ask the ISP about if you don't know.
    Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed?
    • Imulji's avatar
      Imulji
      Guide
      Can’t answer the firmware question as I can’t create the network.
      Shaw XB6 modem in bridge. DHCP.
      Yes One minute off completed.
      • FURRYe38's avatar
        Try using a wired PC and web browser connected at 192.168.1.1 on the RBR and walk thru the setup wizard...
