KingsClass
Sep 22, 2022Aspirant
multi device displayed but only one router and two satellites are connected.
hi everyone,
recently on the orbi admin page, I started seeing lots of devices that are offline (like 98 devices ) but on the HOME page, it still shows correctly -
Attached Devices (RBS760)
Router - 1
Connected Satellites - 2
please let me know if you have any solutions for this. thanks.
Router - 1Connected Satellites - 2please let me know if you have any solutions for this. thanks.What is the problem?
Your router seems to be behaving as designed.
It has remembered devices that were once connected to it. That helps the router to pickup where it left off when these devices try to connect again.
If you don't want to see them, you can clear that list.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Manage network access control lists.While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
If you have more problems with your RBR760, you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi WiFi 6 (AX) and WiFi 6E (AXE) - NETGEAR Communities- KingsClassAspirant
thanks for your reply. the problem is, we never had 98 devices connected. we had only 1 router and 2 satellites always and this has been an issue only for the past week or so and not been able to figure out what changed since we didn't do any update on the firmware or anything as such.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡Try a different web browser?
May need to factory reset and setup from scratch.
it's more than 30 FT btw each device. I don't want to factory reset, that's not the solution for this, then I have to work on the setup for everything- which I hate 🙂 there is no FW update last I checked for the model we have.
KingsClass wrote:
hi everyone,
Thanks for attaching the picture. What happens when you click the "Remove" button by each of the Disconnected satellites?
Do they disappear, only to return?
p.s. I'm assuming that the column with MAC addresses was blocked out. Is there a pattern in those MAC addresses?
CrimpOn wrote:
KingsClass wrote:
hi everyone,
Good call. Are you thinking that all those entries might be the same things in different guises?
Phones that use a random Mac address – think iPhones and Samsungs – might create that behaviour. Each visit of the same phone could add yet another entry.
If that is the case,then we have yet another manifestation of this "security" feature.
If the devices showed up on the Access Control page list of devices that are no longer connected, that would suggest some version of MAC manipulation over time. The regular Attached Devices page displays only devices that are currently connected. For satellites, however, it seems to remember satellites that were part of the network at some time and have become disconnected. I struggle to come up with a scenario that would have 98 devices recognized as satellites but not having a recognizable Netgear MAC address.
