KIMVSR
Jan 05, 2023Tutor
Netgear Orbi AX4200 WiFi Mesh System (RBK752) doesn't boot after factory reset
Dear Netgear community, Could you please help me to understand the following problem: I bought a Netgear Orbi AX4200 WiFi Mesh System (RBK752) on the secondary market. It was used only for a ...
- Jan 05, 2023
I hardwired a PC to the router and was able to connect through 192.168.1.1. Then it was a matter of the setup. I don't know why it didn't work yesterday in that way, but today it helped. Thank for your support on this matter.
KIMVSR
Jan 05, 2023Tutor
Problem solved. Thank you!
Jan 05, 2023Guru - Experienced User
What fixed it? (in case others have the same issue)
And you can mark it solved so others aren't still trying to fix it 🙂
(a backup is also a good idea)
- KIMVSRJan 05, 2023Tutor
- FURRYe38Jan 05, 2023Guru - Experienced User
