jblank1074's avatar
jblank1074
New RBR750 dropping ethernet connection every day.
Greetings all, I bought an RBR750 AX4200 from Amazon in late January, sadly, it's been one problem after another. Every evening sometime between the hours of 8:00 pm and 3:00 am, it loses connection to the ethernet connection (Spectrum cable modem). I'm at my wits end, I have done everything but having to reboot the router daily (or nightly) isn't acceptable for such a pricey product. I am using the current firmware, version V4.6.5.14_2.0.54. Has anyone had this happen? Any ideas? It's not the modem, it was working perfectly fine with the previous router, a Netgear RBR20.
  • FURRYe38's avatar
    Does the Front LED on the RBR turn ON when the happens?
    https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    • jblank1074's avatar
      jblank1074
      Thanks for your reply. The Spectrum box is a Hitron EN2251. Yes, multiple power resets have been performed and nothing positive has resulted from it.
      • FURRYe38's avatar
        What is the CAT# version of the lan cable betweent he modem and router? CAT6 is recommended.
