Dec 05, 2025Guru - Experienced User
NOTICE: New - RBK750/850/860/960 Series Firmware Version 7.2.8.5 Released
Get it here:
Orbi Firmware Releases | NETGEAR Communities
No mention of IPv6 issues being fixed. Just a security fix.
Please try and post any findings or results.
Good Luck.
808stateofmind
Dec 05, 2025Star
Early report after 12 hours,
came from .31 firmware. Flashed dirty with latest version. After several manual reboots, I still have IPV6 working. I had a few times that it disconnected and reconnected, but still working, confirmed.
RBKE964
IPV6 enabled.
I will update the report after 48 hours or if something should happen.
- KMDonlonDec 06, 2025Virtuoso
Mine went out after roughly 24 hours or sooner, didn't get a chance to check exactly...this was with v7.2.8.2. Haven't tried v7.2.8.5 since there was only a mention of security updates.
Let me know what you figure out. What I found was if you reboot IPv6 will connect again and eventually drop after a certain amount of time. So check after a few days without a reboot.
- 808stateofmindDec 06, 2025Star
Sad to report...
IPV6 issues starting to show around the 16 hr. mark for me.
I then performed a factory reset including fresh firmware flashes w/30 sec. resets for all 4 sats, and 1 router. Setup from scratch(2.5 hrs)
After all that, (IPV6 still broken) for me, only on android devices now? IDKY..
So for security reasons, I have chosen to disable IPV6 for now.
Here's my repost update....
So close.....
Thought so, sorry to hear that actually but expected. I have tried and tried to troubleshoot only to conclude Netgear needs to repair it. Since last February with the release of v.7.2.7.15 it has been broken. Figured they would have this resolved by now...
- FURRYe38Dec 08, 2025Guru - Experienced User
Whos your ISP?
Were you using ISP Detected IPv6 DNS or custom DNS?
Which IPv6 mode were you using for IPv6?
808stateofmind wrote:
Sad to report...
So close.....- 808stateofmindDec 08, 2025Star
Whos your ISP? fiber optics
Were you using ISP Detected IPv6 DNS or custom DNS? ISP detected
Which IPv6 mode were you using for IPv6? 6to4 tunnel (my local ISP says that our IPv6 is semi functioning)
