Dec 05, 2025Guru - Experienced User
NOTICE: New - RBK750/850/860/960 Series Firmware Version 7.2.8.5 Released
Get it here:
Orbi Firmware Releases | NETGEAR Communities
No mention of IPv6 issues being fixed. Just a security fix.
Please try and post any findings or results.
Good Luck.
808stateofmind
Dec 05, 2025Star
Early report after 12 hours,
came from .31 firmware. Flashed dirty with latest version. After several manual reboots, I still have IPV6 working. I had a few times that it disconnected and reconnected, but still working, confirmed.
RBKE964
IPV6 enabled.
I will update the report after 48 hours or if something should happen.
KMDonlon
Dec 06, 2025Virtuoso
Mine went out after roughly 24 hours or sooner, didn't get a chance to check exactly...this was with v7.2.8.2. Haven't tried v7.2.8.5 since there was only a mention of security updates.
Let me know what you figure out. What I found was if you reboot IPv6 will connect again and eventually drop after a certain amount of time. So check after a few days without a reboot.
