ymd's avatar
ymd
Orbi 750 as cable connected wifi extender.
Hi,
I moved to a new place with ethernet cables going from a central room into all rooms. I plan to use a switch and put my orbi devices into different rooms, all connected to this switch, for wifi coverage in all rooms.
Is there a mode for such use case? Otherwise, are there any other recommendations for us? The place were moving into will have gigabit fiber up/down, is about 2500 sqft in 1 story.
  • You should go
    modem--->router---->switch/satellites
    Otherwise if you're going modem/ont-----switch-----orbi (in router mode)  the devices connected to the switch might be getting a public ip address from your ISP and not one of the private one from the router. Plus its less secure.
  • plemans's avatar
    What actual system do you have? There's the CBK version of the orbi that is coax cable only and the RBK version that is a router.
    So if you have fibre, its good to know what router you're starting with.
    • ymd's avatar
      ymd
      I'm not 100% sure but my Orbi does only router stuff. I was on comcast and before I have coax coming to a modem and then ethernet to orbi. I imagine that on fiber it would be similar that I'll have a fiber modem stuff but not sure.
      So my setup would look like:
      • ISP
      • Modem
      • Switch
        • Orbi main
        • Orbi satellite
        • Orbi satellite
        • Ps5 and stuff
      Am I understanding correctly?
      Also, I'm still fascinated that a switch can magically do all the traffic for me that it just works after I have ethernet plugged in and I can just sit back and enjoy its hard work. It's not like that the switch has a WAN port like on a router (and I don't understand the difference). Or have I missed anything?
      • ymd's avatar
        ymd
        Otherwise, should I do
        • ISP
        • Modem
        • Orbi main wan
        • Switch
          • Orbi satellite
          • Orbi satellite
          • Other stuff
        Not sure which should I do. Please suggest. Thanks in advance!
