laltaffer's avatar
laltaffer
Orbi 750s lost satellite during firmware update
One of my satellites is no longer connecting. This started two firmware updates ago and I think the one sat didn't get updated. Now it won't sync or connect no matter which tool (app or website) I use.  Occasionally I get it to show as one of the devices but it says its not connected.
any tips on how to for an update to a satellite ?
  • plemans's avatar
    have you tried hardwiring it into the router?
    • laltaffer's avatar
      laltaffer
      I have it hardwired to the router. But it only shows up as a connected device, no different than my PS5. I got its IP address but none of the admin/PW combos seem to work. Took the one from the bottom of the satellite it won't work.
      Any ideas on what to do next?
  • FURRYe38's avatar
    Be sure the RBS was updated first before the RBR.
      laltaffer
      I have not done a full RBR + RBS factory reset. I have hit and held the RESET button on the RBS but that doesn't seem to have done much for me. Currently I don't see any way for me to check on the firmware of the RBS in question. It shows up as a wired connection but not as another satellite so it doesn't give me any more information than it does when showing my phone is connected.
      The RBR and RBS that are working correctly are running V4.6.5.14_2.0.54
      To do a full factory reset do I need to unplug everything for a day? I think I read that somewhere and honestly not sure I can do that. I'd have to go get another set to run in the interim. If not what are the steps to do a factory reset?
      Also its worth noting that the 'bad' RBS does occasionally do the white light blinking, which I have read means bad firmware.. I just have not found a way to get it connected so I can manually update it
