zhuch07's avatar
zhuch07
Follower
Sep 09, 2021
Orbi 753 drops internet connections every few days, unplug plug connection to modem fixes it
(Reposting from https://community.netgear.com/t5/Orbi/Orbi-753-drops-internet-connections-every-few-days-unplug-plug/m-p/2137874/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufEtUQ1pRVkZVOFU0OVc4fDIxMzc4NzR8U1VCU0NSSVBUSU9OU3xoSw#M125674 based on the suggestion)
My Orbi 753 mesh was working fine for a few months after I purchased it. But now every few days (every 4-5 days), the router would lost internet connection with the purple light on. I had to manually unplug and plug the connection to modem. And it immediately fixes itself. I have replaced the cable from modem to router, but it didn't help. Looking at the logs, there was not much useful infomration either.
Any advise on how to debug and fix this issue? Apology if this has already been discussed somewhere.
Thanks!
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    • ezpzDUDE's avatar
      ezpzDUDE
      Guide
      I noticed that the user did not reply to your questions regading the issue of the RBK753S dropping internet connection.
      I have had three call in regarding this issue.  And our connection drops throughout the day.  I noticed that this issue popped up in 2020 and the suggestion was to upgrade to beta firmware.  My unit has been upgraded twice per the suggestion of Premium Support.  And there has been no improvement and in fact, upload has slowed down considerably.
      I am beginning to suspect that the Orbi line has some issues and that I should return this for something else?  Or are there any suggestions please?  Thank you
      My current fw is V4.6.5.14_2.0.54
      My unit is RBK753R-100NAS with two RBK753S units
      • FURRYe38's avatar
        Yes, there are some issues with current FW on Orbi systems. NG IS aware.
        Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
        I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
        Press the back reset button for 15 seconds then release.
        https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
  • FURRYe38's avatar
    Any progress on this?
    Thanks!
  • FURRYe38's avatar
    Thanks!
