David9's avatar
David9
Orbi 850 running V7.2.8.5_5.1.21 dhcp issues
Hi I recently switched my Orbi 850 back to router mode from AP mode as I have a new ISP.
What i've found within a day is that the dhcp function on the Orbi 850 (+1 satellite) running V7.2.8.5_5.1.21 is incredibly flaky.
We have about 80 devices at home, the majority of which are nanoleaf light bulbs (~40 or so), sonos devices and various other "smart" appliances.
I've rebooted it multiple times to try and get things working, and it works for some but then other devices cannot get connected. Symptoms I've seen are:
  • Windows PCs getting the default microsoft IP address of 169.254, which means it could not get an IP address.
  • Devices that were connected before the reboot won't connect after.
  • Devices showing incorrect device "names" against the respective mac address in the device list.
Overall it seems to be incredibly unreliable.
Anyone else experienced this?
  • In order to test we may need to reset all of our end-points and reset the Orbi back to router mode. All up about an hours effort, not counting reconnecting some 40 lights back to the app.
    The way most devices to wifi works is that they won't disconnect from a sourced until a lower level signal threshold is dropped below. There are also "hold timers" before switching. Again the issue here isn't the wifi connectivity but rather the DHCP function. I've read that "slowly adding" devices may help but that is all just a work around for what appears to be bad software, firmware or hardware.
    I've also not been able to find anywhere that this is resolved in later models.
  • I'm not sure that the point is being understood. I can play with signal strenght, but what you are suggesting doesn't really make sense. The issue is that the DHCP server cannot allocate addresses. This is seen through it partially negotiating and then the device defaulting to a "self assigned" 169.254 address. Wireless connectivity in AP mode, where another device is the DHCP server, doesn't have this issue.
    Can you clarify your logic?
    • StephenB's avatar
      The theory is that some of your devices might be repeatedly dropping their connection, and needlessly switching to another mesh element.  And that those switches might be triggering the problem.
      Obviously speculative (and perhaps unlikely), but easy to test.
  • It appears to allow the amount of devices to connect via wifi when NOT a DHCP server and it is the DHCP server function that is the issue when in router mode.
    ....and yes I did factory reset it. ...twice.
    Regarding the connectivity etc. I have worked in telecomms and IT networking for over 38 years. I understand networks, routing, subnets and DHCP servers. There was no ISP router in the new connection when initally connected to the Orbi "WAN" port. To resolve the issue in the interim I've installed an old ISP router, which now acts as the DHCP for 192.168.1.0/24 and reverted the Orbi to AP mode. It appears to have stabilised for now, but you can never tell whether all devices are working. Unfortunately that old ISP router only allows up to 32 IP address reservations.
    I should also state, that over the years I've had the orbi I do have to reboot it every few weeks to keep it "reliable".
    • FURRYe38's avatar
      What's the size of the home in sq feet?
      • David9's avatar
        David9
        It is currently approximately 125 square metres, Single level 3 bedroom apartment. Previously we had in a 100 square metre two storey apartment. I'll come to the issue here, which is the DHCP function when in router mode. I can live with AP mode and rebooting every few weeks or so, but the DHCP router mode function was abysmal, and from what I've read I'm not the first person to report this issue.
  • The ISP provides a fibre service and then Ethernet converter as an NTU/modem. It is a direct connection from that to the WAN port on the ORbi 850. This is not the issue.
    I have tried changing the DHCP range from default to .50 to .199 but made no difference. I don't want to use an IOT. But wouldn't that use the same DHCP range or does that have its own range?
    • FURRYe38's avatar
      I would try the IoT network for your IoT stuff.
      50 devices here. All on main WLAN.
      I might bring my 850 series out and check this.
  • Um no. I switched the Orbi 850 from AP mode to Router mode and connected it directly to the ISP, no other router in between. I made it the DHCP, as is the norm for you ISP router. It is this functionality that is flaky as hell, failing within a few hours. Couldn't connect any new devices. Cannot configure any timers.
  • FURRYe38's avatar
    What brand and model# is the ISP modem that the RBR is connected too?
    CAT# LAN cable used in between the modem and RBR?
    What IP address pool string are you using on the RBR? Default 192.168.1.1?
    Might try using a different DHCP IP address pool range. .100 to .200. I do.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
    Make sure all wifi adatper drivers are up to date for PCs that have these adapters.
    Make use of the separate IoT network for IoT devices
    Use manual channels 1 and 40 or 11 and 48.
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
    I've used this same FW version on my 960 series Orbi, same code base, bit different WIFI features, saw zero issues with DHCP and devices connected. I know my 850 series would work just as good.
    David9​
  • Looks like it is time to switch to TP-link. sick of these issues.
  • All reserved addresses were wiped during the change and re-setting up dhcp on the orbi as the router.
