nadrux
Dec 29, 2024Tutor
Orbi 860 ssid iot or 850
hello i wanted to know if those models have the ssid iot feature ? and wich is better to buy in term of update futurproof etc. (860 is from 2023 and the other from 2020)
than you !
Since the 860 series has FW v7 support, yes, it has the IoT support as well.
- nadruxTutor
thank you for your answer and in term of update/ stability is it better then the old 850 ? ( recent update)
I've not had the 860 series to test with, only the 850 series. I think the only difference was the WAN port, the 860 series has a 10Gb WAN port where the 850 has a 2.5Gb speed on the WAN port. I think everything else was the same. Something you can check out between each model spec sheet to see.
