Oksell
Jul 16, 2023Follower
Orbi AX4200 Satellite with AX5400 router?
I have 2 Orbi AX4200 satellites (RBS752).
Can I buy the Orbi AX5400 (RBK763s - with a router and 2 satellites) and also use my existing satellites for a ”larger” mesh network?
So the short question is, are these two different Orbi-versions compatible and able to create a mesh network?
1 Reply
Netgear published this table of which satellites are compatible with which routers:
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible?article=000065169
The table indicates that the 750 satellites are not compatible with the 760 router.
