Manic451
Oct 29, 2022Aspirant
Orbi CBR750 internet dropping
I have been battling with my orbi dropping the internet connection multiple times a day.
It is a CBR750, no satellites. ISP has tested connection up to it multiple times with no issues. Firmware version 4.6.5.8.
It will randomly lose internet connection, can be fixed by resetting it. This fixes lasts for minutes or hours. When I am away from the home, I will get notifications from various connected devices that they have lost internet connection. I have completed a factory reset with no change. Powering it off for 1 minute and restarting has no effect.
It does not matter if the devices are wired or wirelessly connected, they will all lose connection until it is rebooted.
- Manic451AspirantI have been battling with my orbi dropping the internet connection multiple times a day.
It does not matter if the devices are wired or wirelessly connected, they will all lose connection until it is rebooted. - FURRYe38Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-routerHave the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html- Manic451AspirantUpdate:
I attempted to get a log, I am now unable to login to the orbi. Every time I enter the username and password, it tells me to reset the password…
As I mentioned in the original post, all lined up to the orbi have been tested and confirmed good by the ISP.- FURRYe38Guru - Experienced User
Be sure to clear out all browser caches before entering the modems web page.
Try a different browser to log in.
Will need to review the cable connections and event logs pages here.
