skrishnan37
May 21, 2020Aspirant
Orbi RBK852-Connect to satellites by Ethernet?
Recently got the RBK852 with 2 satellites. Are any of the ports on the satellites WAN & able to connect to the main unit or is it all remotely? (My house has ethernet ports throughout so I'm not worried about one unit being too close to another)
- skrishnan37AspirantWith those speeds, should I be using cat 6 cables only?
And are Ethernet cables like cell phone charging cables. The longer the cable, the less the performance?- FURRYe38Guru - Experienced User
At minimum, yes. Cat6 or higher. I've been using CAT6 for years. Great performances.
No they are not.
- jcrimTutor
I just received a new RBK752 pair last week, and I use Ethernet backhaul between the router and the Satellite. I'm actually using cat5e - cat6 would be preferable, but it's what I had when I installed the cable for my TV a few years ago. I'm getting > 300Mbps over it, even though I believe it's rated lower.
IMO an ethernet backhaul is always preferable to a wireless backhaul, if you can use it. Fortunately the RBK752 and RBK852 support it. It was automatically detected upon setup, so very easy to configure.
Enjoy it. :smileywink:
What does it do to the backhaul wireless radios if ethernet backhaul is turned on? Are those radios freed up to handle more traffic?
