Ninjakeks_5's avatar
Aug 16, 2021
Orbi RBR750 - Interruptions on WEBEX & MS Teams Calls
Hey guys
I've recently installed my Orbi system (RBR750; one satellite). It's attached to a cable modem which I've set to bridge mode. I'm having since then trouble on every WEBEX or MS Teams Call. The voice output is constantly being interrupted.
I’ve tried it with my Laptop, PC and iPhone; connected directly to the Orbi router or to the satellite. The only thing helping, is when I connect via mobile network, then the issue disappears.
I’ve done several tests, the ping is good, the speed is plenty (over 600 Mbps download). Has it maybe to do with the new Firmware (everything is up-to-date)?
Kind regards
NK
  • FURRYe38's avatar
    Could try this this, put the modem back in to router mode and configure the RBR for AP mode. See if the problem continues...
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    Try disabling AX mode on the RBR under Basic tab/wireless settings...
    • Ninjakeks_5's avatar
      Ninjakeks_5
      Tutor
      Hi FURRYE38
      Firmware: V4.6.3.7_2.0.49
      ISP Modem: ARRIS TG3492LG-LC
      Sq Ft Home: 1400
      Distance R and S: 50 Ft
      20/40Mhz Coexistence: Disabled
      CTS: Set to 2347 for 2.4 GHz & 5 GHz (see attachment)
      AX: Not disabled - I have a specific antenna for AX mode on my PC
      Can you tell me what the 20/40Mhz Coexistence and the CTS setting to 2347 does?
      Is the issue Firmware related?
      I've tested it quickly with two call and noticed some drops. I'll have to test it during the coming days on a proper call. Keep you updated.
      Regards
      NJ
