TexasPapi
Jun 13, 2025Tutor
Orbi RBR750P Wi-Fi Drops
I bought a new RBR750P with one satellite in April 2025. It's been problematic from the outset, insofar as I am getting random wi-fi drops. Meaning:
- the SSID disappears from the list of available networks
- multiple devices (e.g. my MacBook and iPad) connected to that SSID lose their wi-fi connection
- all SSIDs are lost e.g. the main network and the guest network
- neither the router or satellite are allowing connections
- the device is still powered on, and my knowledge never lost power
- after a few minutes the network will come back up, but in spite of having "auto-join" selected, I have to manually reconnect from my MacBook and iPad
- it happens randomly, maybe every couple of days, plus or minus 1
Some other data points:
- the router is plugged into the little network closet in the laundry room
- router is less than 20 feet away from my MacBook and iPad
- this is not a matter of weak signal -- there is no wifi to connect to at any strength
- satellite is upstairs, but it shouldn't matter because there is no SSID at all
- house is 4000 sq ft, but it shouldn't matter when my devices are 20 feet from the router
- I do have Armor, and yes it is enabled, and no I don't plan on disabling it--I'm paying an incremental subscription cost for this and I want the functionality I've paid for
- I usually have 20-25 devices connected, on a combination of router & satellite connection--almost all of those are very low traffic--thermostats, fridge, water leak detector, etc.
It's really aggravating. I expect network to be solid as a rock. My attitude right now is that of General McKittrick in WarGames: "After careful consideration I've determined that your newfangled system sucks". Is anyone else experiencing this?
I had an interesting experience yesterday that I'll share, and I suppose wrap this thread up while I'm at it.
Over the course of...I don't know, a few weeks or a month, I kept getting drop-outs periodically. Annoying but I would just push through. They started getting more frequent toward the end, until yesterday it culminated in me not being able to keep the connection up for longer than about 3 minutes. Literally I'm trying to have a conversation with ChatGPT from my Mac about what's going on and what to do, and I can't because the connection is bouncing so much.
Interestingly, this time it was only happening from my MacBook Pro--I was watching Netflix from my iPad on the same network during the whole process (except when I manually rebooted the router or bounced the power). Which is different from what I recall when I opened this thread, and of course makes me think there must be a problem specific to my MacBook, whether hardware or software. Did the OS get an update that broke it? Is my wireless radio just dying? Have I got a VPN causing a problem? Is there a client-side wi-fi setting I need to change? Is there a router configuration that could stabilize it?
I actually started shopping for an Eero. Then I remembered this conversation, and among the many steps ChatGPT had me try, the same recommendation appeared: shut down Armor. So after going through the mind-boggling mobile UI to find this setting, I shut it down. It was a miracle cure. Immediate relief from the symptoms. Network's been up since then.
So, I'm not sure what to make of this. The fact that my iPad and iPhone behave differently makes me want to give Orbi the benefit of the doubt. On the other hand, Armor on the router seems like it should be a total black box with the same behavior across any client. In any case, I'm sick of dealing with it. Unfortunately it appears I wasted my money on the Armor subscription (of which I've used for maybe 4-6 (painful) months out of the 12, because I won't be turning it back on.
This reared its ugly head again. My network was bouncing down and up, with just minutes in between. I remembered this experience and thought I'd go check the router setting for Armor--which I have not touched in nearly a year since the last fiasco.
First I opened the web admin console and there was a firmware update available--I received no notification for that so I guess I'm glad I noticed it. Got the new firmware installed.For some reason this also reset my router such that it thought it was a new device, so I had to go through that whole flow again. Same problem, network bouncing down and up.
Back into the admin console. Lo and behold, there is Armor Security with ENABLED in the admin console on the web browser. I definitely did not re-enable this myself. So I searched around for the setting to disable it and then remembered -- oh yeah, for some reason changing that setting is only in the app, and nowhere near any intuitive spot. Finally found it, and disabled it. Network's been up for the last 10 minutes, which is better than before, and I assume this is the same problem as before -- Armor sucks, and the same solution as before -- disable it.
Everything about this experience is user un-friendly. Not getting a notification an update is needed. Having to do the new router flow again. Somehow re-enabling a setting that I most definitely don't want. The fact that Armor wrecks my connectivity. Hell, even going back into this forum was not easy, since SSO doesn't carry over from Netgear.com to here. Seriously, Netgear--do better.
Notifications about FW updates are seen on the web page or in the Orbi app.
Also if you had FW updates enabled on the RBR, then this may have auto updated on it's own as well.
Always check the forums or NGs Download site for new updates or ask about them here.
Save off a new RBR backup config for safe keeping. Saves time if a reset or setup is needed.
Not the first time Armor has been the culprit. Glad you got it figured out. Thank you for coming back and updating us.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemEnjoy. 📡
Well, I give up. Prior to this post, I'd reset the router multiple times, and it was recurring at a completely intolerable frequency nonetheless. Ever since I put this post up, this problem has not recurred. I have no idea how one explains that, as there's been no configuration change on my side, but for enabling log emails daily, which of course tells us nothing when the problem doesn't recur. So, I've disabled log emailing and put this on the back burner.
I recommend that you make contact with NG support and see what your RMA options are. Maybe a faulty system from the get go since you mentioned having reset the system multiple times and issues are still happening. Ask aobut a cross shipping RMA option.
I see there hasn't been any FW updates and not sure if this system will see any thing.
Maybe I wasn't clear. The problem is not recurring presently.
Just to update the group. I've had this running for the past week or so with the log file being emailed to me every hour. It hasn't bounced during this time, at least not during a time when I've been sitting at the computer (I'm here a lot as I work from home). So that's nice because when I opened this discussion it was more frequent. Not nice insofar as all I can do is wait for the problem to duplicate.
Does anything appear in the Orbi Log File when this happens?
This system appears to be within the magic '90 days of complimentary support' from Netgear. What does Netgear support say about this situation?
Ah I forgot to answer about what Netgear says. This has not been reported to Netgear support yet.
I don't now, I haven't studied it. Also, it appears the log has a 24-hour loopback window, so whatever it might have previously told us, I've lost. I'm going to turn on scheduled log emails hourly, and see if we capture anything useful the next time wi-fi bounces.
*lookback
A couple more thoughts:
- This frequently happens when I'm just sitting here in my home office, as I am now, and as it did recur today. So the devices aren't moving around, which should also imply that the signal strength is constant.
- Sucks that this is hard to test. E.g. if I did disable Armor, I'd still need to watch what happens for several days before making any determination about the result.
Does the front LED on the RBR or RBS turn on PINK or blink any?
Does this happen if you temporary disable Armor?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰Might try the RBR out in a open space instead of a closet area. This may inhibit good wifi signal travel.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/kb/en-orbi-knowledge-sharing/netgear-mobile-applications-and-androidapplewindows-devices-faq/2457046Thank you for your thoughtful reply. You’ll forgive any perceived pushback below. It’s not you, it’s the problem.
On the RBR750P I think the LED is atop the unit. I haven’t noticed anything but I’ll honestly have to take a closer look next time to be sure.
I don’t know, I’d have to test that. But as I said in my original post, I’m not keen to do this. I’m assuming/aware you mean just to test, not permanently. But if I find that Armor is behind the problem, this is not helpful to me—I want that functionality and I’m paying an incremental subscription price for it. Netgear needs to test that, not expect me to lose paid functionality in the meantime.
What is the distance between the router and satellite(s)? 30 feet or more is recommended…
I have one satellite, it is upstairs while the router is down, so I imagine more than 30 feet away. But I also don’t understand the relevance, if we are talking about an SSID that drops completely, and devices that are previously connected to the router, not the satellite.
Might try the RBR out in an open space instead of a closet area. This may inhibit good wifi signal travel.
I appreciate the suggestion but I’m not going to do this. The router is less than 20 feet from the devices mentioned here, with open doors in between. What I meant buy “closet” is a fancy Leviton wall-mounted network enclosure of thin plastic, specifically constructed to be porous for wi-fi signals, and my previous router (also an Orbi) did not have this problem in the same setting. That’s where I want the router to be, and I can’t fathom how the current location is problematic for any self-respecting router. I also don’t understand why strength of wi-fi signal would matter, if there is no wi-fi network to connect to at all?
The 2.4Ghz channel is Auto. The 5g channel is 40 (I read something previously with the same suggestion, and made that change some time back). All the devices I’ve mentioned here are connecting to the router (not satellite), on the 5g (not 2.4g) channel.
This is set to “Fixed” on my MacBook and iPad presently, for my home network. So it’s not actually “off” per your suggestion, but it does mean the MAC address is unchanging on this network. The router doesn’t seem to be having any problem identifying my device. For example, it appears consistently in the device list, with the same MAC address and the same device model, name, and type. I can look into this but—leaving room for my own ignorance or misunderstanding—how is an unchanging client-side MAC address causing the router to drop wi-fi, and stop broadcasting SSID, for multiple connected devices, all at the same time?I’d be more keen to test client-side settings and whatnot if the network was up, or if I had issues that differed across devices, at least in terms of timing of recurrence. As it stands, it’s hard for me to imagine this issue being anywhere but in the router.
Well we can't know for sure if Armor could be at fault or not unless you give it a try. If it is a prblem then we can let NG know about that so they can fix it. Try this will either help rule out Armor or point to it as a culprit. It won't bother anything if Armor is disabled for a few days either.
Id also turn off the RBS to help rule anything out there. RBS is doubtful being the culprit.
Last resort would be a factory reset and setup from scratch, with out Armor being enabled first, then if nothing is seen, then enable armor and continue to check for this issue.
All of these questions and suggestions are to help narrow down and figure out where the problem maybe, in router or else where. Gotta start some place.
I forgot to mention, I'm on the latest firmware as of Jun 13 2025, which means:
Router: V6.3.8.5_1.4.80
Satellite: V6.3.8.5
