NirOnE's avatar
NirOnE
Guide
Sep 01, 2021
Orbi shutting down with high downloads (orbi RBR750)
Hello everyone,
I have a strange issue with my orbi router.
Setup : Comcast modem (bridge mode) - Orbi router (with 2 satellites) - Computer (windows/Linux) connected with cable.
Orbi firmware : V4.6.3.7_2.0.49 / SSID and password changed for the Wi-Fi settings.
Everything works well until I am updating big games (example here Call of Duty Warzone)
imgur images link
1 minute into the download, the whole system crash (no internet), and impossible to connect/ping the router.
The orbi light goes to purple and the internet never comes back until I reboot the router.
I checked the Comcast modem, no problem there, so the issue only seems to come from the orbi.
Do you know where it is coming from, or if I can fix that issue through the settings ?
Thank you for the help!
    • NirOnE's avatar
      NirOnE
      Guide
      yes, sorry I searched the forum badly
      So it seems the only solution is to downgrade the FW to v3 ?
      I called the help but they did not know what was wong.
      • FURRYe38's avatar
        Guru
        No sure if the problem was resolved by downgrading.
        I recommend contacting NG support and let them know what your seeing along with including the link I sent as well.
        I tried to reproduce on mine and couldn't so this seems more particular for some of use with more partiuclar configurations and services that your downloading from thru the ORbi that causes this problem. Possible HW fault as well. Something NG needs to look into for you.
        Blanca_O DarrenM
  • Can confirm I have the same issue and its definitely the fw that introduced this. Download size is pretty much anything over 230 mb's that causes it to lock up the router and crash the network. Only on ethernet connections and with any lan port on the router and any device wired in. Admin portal is unreachable when this happens, resulting in having to hard reboot everytime.
    • NirOnE's avatar
      NirOnE
      Guide
      I have been in contact with the support team 9 times now and they can not provide me with any solution... I will try the AP mode this week end as last resort. If that does not work I might return it.
      • FURRYe38's avatar
        Guru
        Did you get the beta for your system?
