Gdogghbk
Feb 13, 2021Aspirant
Orbi WiFi Crashing
Hi All,
I recently purchased the Orbi AX6000 RBK852 to provide Mesh WiFi in my home...
Upon initial setup, everything went great! I have an Arris SB6190 connected to the Orbi Router in my living room, with the Satellite on the 2nd Floor. Initially I was getting high WiFi speeds no problem. There was a initial WiFi crash the first night (We attributed it to network issues from the Super Bowl), but it rebounded and worked great all week...
Then came this past week... the WiFi keeps crashing to a dead halt. We’re talking 0.05 on Speedtest and WiFi devices rendered useless. The Hardwired devices like our Apple TV? Not even a blip... Strange thing right?
So I Factory Reset everything, and started to reestablish the network. However, in order to even get the Orbi’s to establish the network I had to turn our TV/DirecTV off. When I did? Network back up! So I tested everything again, TV on and TV off, the WiFi still crashed hard with the TV on...
Now to explain our setup, we have an LG CX, and Direct TV with a Genie 2 and the wireless Mini-Clients. Everything from the DirectTV to Gaming Systems to our Soundbar is Hardwired (why I wanted this Orbi with its multiple LAN ports). The only things using the WiFi are upstairs smart TV’s our phones, tablets, and laptops.
I’ve reached out to support and they helped me change frequencies, among other various things, but I’ve exhausted those over the week & still the same result! TV on, down goes the WiFi, crashing from 400mbps to 0... TV off? WiFi pops back up! I’ve got a good 3-5 ft separating the TV from the Orbi, and probably 5-7 feet away from the Direct TV Genie 2 Hub.
Has anyone experienced anything like this?
That FW version are you usuing?
v12 is the latest:
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?- GdogghbkAspirant
v12 is the latest:
**It’s on the Latest Version, did the Update Upon Setup**
**Home is multi-level, 1800 sq ft**
**Router is on 1st Floor, Satellite is on the 2nd Floor, for sure more than 30ft apart walking distance, may be closer through floors?**
**I went through every channel and every combo over the last week, even altering CTS/RTS as Support suggested**
**Probably everyone in the neighborhood, lots of WiFi’s show up in NetSpot, but none appeared overpowering?**
Hopefully I answered those well enough...- FURRYe38Guru - Experienced User
So if you turn OFF the RBS, does the wifi on the RBR still not work well?
