Axl2020's avatar
Axl2020
Orby 750 can't assign IP to guest wifi
Hello, my orby RBR750 with Firmware Version V4.6.5.14_2.0.54 and with attached 2 satellite is cofiguret as a router.
I've set up the guest wifi. The problem seems that on this wifi the dhcp don't assign any ip address.
Someone have solved this problem?
Thanks
Massimo
  • Has a factory reset and setup from scratch been performed with a ethernet connected PC and web browser?
    Even if you disable WiFi Private Address on the iPhone, it will not connect?
    If you disable the security mode and set to NONE, does anything connect to GN? Re-enable WPA2 after testing this.
    What mode is the modem working in? Router or bridged?
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
  • FURRYe38's avatar
    What devices are you connecting to the Guest Network?
    What devices have you connected to the GN?
    I believe the IP address will differ from the main LAN network IP address pool.
    • Axl2020's avatar
      Axl2020
      I've tryed to connect my iPhone (ios 15.4) and the macbook Pro with Montery. I've tryed also with an android and a win pc.
      I'm unable to connect any devices.
      The Orby is connect to a Vodafone Station 6 (firmware:XF6_3.0.17.04, HW version RHG3006 v1).
      • FURRYe38's avatar
        Couple of options,
