thooper50
Feb 17, 2022Aspirant
RBK 853 Random WiFi Drop-outs & Additional Satellight Appearing
New installation / purchase so less than 24hrs old... Is there an issue with RBK850 firmware version v4.6.3.16_2.0.51 constantly disconnecting and then reconnecting? I also keep getting an additi...
Feb 17, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is there an issue with RBK850 firmware version v4.6.3.16_2.0.51 constantly disconnecting and then reconnecting? I also keep getting an additional satellite appliance randomly, when the satellite drops (so far both satellites have dropped at least 2-3 times each..
So far, not impressed by this purchase and unless I can get stability will be heading back for a refund.
Tried reseting config, satellites etc. as it seems to be dropping the satellites and thus anything connected via wifi or cable.
