wouterlet's avatar
wouterlet
RBK853 seems to have no internet for a sec after opening connection
I have an RBK853, the connectionrange is great. Speed is very good. But I have the thing when I open a website on my phone or laptop for a sec there is an an error DNS_PROBE_FINISHED_NXDOMAIN. When I open that tab it opens the website direct.
Next to that I have a Harmony Hub. Also the app can't find the HUB sometimes, when I reopen the app it's fine again. So it also seems the same problem?
I tried setting the DNS server in the RBK853 to 8.8.8.8. but it didn't help. When I set this DNS on my laptop it seems fine, but this is not the solution I want. Because this leaves me with my Harmony problem and also phones.
I do have a not ideal situation with an Fritzbox 7590 from my provider witch can't be set in bridge mode according to them...
I set him to fixed IP but I can imagen that this isn't perfect. But that shouldn't be the problem with my Harmony because this is working only in my wifi network (It keeps working when my internet is down...)
Is there anyone who can help me with this problem?
  • FURRYe38's avatar
    If your ISP modem has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    I recommend trying option #2 first...
    • arlomike's avatar
      arlomike
      Apprentice
      Sounds like the infamous DNS issue with Orbi. Do a search on this forum
      • FURRYe38's avatar
        Let check the configuration of the modem first...they maybe in a double NAT condition.
    • wouterlet's avatar
      wouterlet
      Thanks for your answer! The first option is sadly impossible. I called them a few times but the same answer everytime....
      I think option 2 is allready the situation here. I attached a screenshot. But I had my Orbi already set as exposed host to be able to connect to my domotica.
      Can you check if I'm right? Could it still be helpfull to test option 3? I'm not excited to test it since I set up multiple fixed IP adresses and hope other devices won't get problems.
      • FURRYe38's avatar
        I would ask the ISP about if your Exposed Host configuration is correct. It looks like it.
        Been a known issue as well that some ISP modems DMZ or Exposed Hosts may not work well.
        Yes, try AP mode with the RBR850. You'll need to remove the Exposed Host configuration from the modem though when you do this.
