stig911t's avatar
stig911t
RBKE963 has slow ethernet performance
Got 2 gig fiber installed and getting 2.3 gig up and down on the frontier provided Sagecom device. I plugged the orbi in using the same cables and only get 1.7 (at most) usually 1.2 down and 2.3 up. Are there any settings or something I’m missing to help the download speeds? I don’t think cabling is the issue as I’m using the same cables on the Sagecom. I also don’t have any other devices connected to the orbi, just the one computer on ethernet for testing.
The orbi seems to start the download at 1.8-2 gigs but throttles down by the end.
  • What Firmware version is currently loaded?
    What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
    Are you using the 2.5Gb LAN port on the back of the RBR to test speeds with a wired PC connected and using Ooklas installable speed test app on the PC?
    Is the PC supporting of having a 2.5G or higher ethernet adapter?
    What wireless devices do you have?
    CAT# lan cable are you using? CAT6A STP cable is recommended.
