Jonnybunker's avatar
Nov 22, 2020
RBR 750 and 2 RBS 750 - All devices Connecting to Router Only
I was doing some troubleshooting on something compeltetely unrelated, but then realized that all of my devices are showing connecting to only my main Router, the RBR750. I have checked both the satellites, refreshed through the app, and still it shows that nothing is connected to them. I then logged into the administrative console and still found that everything is showing only connected to the Router only. I searched the community and thread and found a few things about it, but verified all of the settings and suggestions i could . A few people mentioned "Daisy Chain Settings" however, i do not have any setting with that name. This is on the RBR 750 AX band router.
My questions
Are devices actually all connecting through the Satellites as well and just not showing correctly?
The Satellites are only showing 5ghz band, when i thought in the past it would show both 2.4ghz/5ghz - I thought that was the benefit of AX/Wifi 6 is that even in a mesh it can intelligently swap between on both the Router and the Satellites?
I cannot find a daisy chain setting, is there something i am missing?
My Setup: Comcast ISP Blast Pro 500MB - Motorolla SB 6190, RBR 750 and 2 RBS 750 - AX 4200, Netgear Armor is enabled
I have tried looking at all settings in the Orbi App, the Admin Panel and cannot find anything to change.
Thanks!
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    What do you see if you log into the RBS web pages?
    Test this by taking a mobile device near the RBS. Turn OFF the wifi radio on the devices for 5 seconds then back on. Then check the RBS web page.
    Try disabling Armor...
    • Jonnybunker's avatar
      Jonnybunker
      Guide
      Sorry , forgot those details !
      Here is setup :
      Firmware V3.2.16.6_1.4.4
      3 story house , 2950 sq feet , built 2019
      Main Router up on 3rd floor master closet- east side of house , where modem is (I know probably not ideal)
      RBS750 on 2nd floor, west side of house
      RBS750 on 1st floor , east side of house
      Disabled Armor to test and will try the other troubleshooting as well! Attached the router firmware and this matched the Satellite Firmware when I checked earlier. Did a “check for new” but didn’t find anything
      Thanks foe the help !
      The odd thing is when I logged into Armor , it showed a ton more devices connected than my Orbi app was displaying. Rebooting router now to see if armor being disabled fixes
      • FURRYe38's avatar
        Be sure to power OFF the RBR after disabling Armor then back ON after 30 seconds.
        Try turning down the power output of the RBR as well.
