CCADNG's avatar
CCADNG
RBR750 - Power cycling issues
Hi All,
I have lost wifi connectivity whenever the device is powercycled, initially i didnt know what to do to get back wifi so i had to factory reset multiple times, after a support case troubleshooting which asked me to do MAC spoofing worked as turn around and was determined as a hardware issue from Netgear support, i got a new RBR750 but i still have same issue with powercycling.
Comcast XB7 Bridge Mode to RBR750 - Firmware : V4.6.5.14_2.0.54
NG says they have not heard this issue from other users, can someone help me to see if this really not an issue with everyone or is it issue with only my hardware/software.
FURRYe38 CrimpOn Can you guys please help me with this issue
  • CrimpOn's avatar
    CrimpOn
    There is a technical difference between losing WiFi connectivity and losing access to the internet. When this happens
    • Devices are unable to connect to the Orbi WiFi?... or
    • They connect to the Orbi WiFi, but cannot access the internet?
      (for example, a device could open the web page http://orbilogin.net (or perhaps http://192.168.1.1)
    By MAC spoofing, which option did Netgear have you use on the Internet setup page for "Router MAC Address"?
    Where did you get the MAC address to enter?
    Is there a reason the Orbi is powercycled often?  (Mine can go six months without a reboot.)
    Did Netgear support "close" this case?  (None of us on the forum have equipment purchased recently enough to qualify for that 90 day support window and are jealous of those of you who can contact support)
    • CCADNG's avatar
      CCADNG
      Thanks for the reply CrimpOn , my devices are connected to OrbiWifi but no Internet, we moved to new home and i am trying to install some IOT devices and have to switch the power off/on multiple times, also the placement changes to accomodate where it belongs.
      I am shocked to see it doesnt connect back seamlessly.
  • FURRYe38's avatar
    What do you mean by powercycling? Are you turning OFF the RBR then back ON, or is the RBR rebooting on it's own?
    You might reivew this:
    https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR750-RBS750-Firmware-Version-v4-6-7-5-Released/m-p/2182131/highlight/true#M25411
    CCADNG wrote:
    Hi All,
    • CCADNG's avatar
      CCADNG
      Thanks for your reply FURRYe38
      As i mentioned we moved to new home and had to switch off power on/off for various reasons (placement/install other smart switches etc.)
      I have Xfinity Comcast XB7 in bridge mode to connect to Orbi, let me know if there is anything i can provide to help me resolve my issue
      • FURRYe38's avatar
        You might update FW and see if this helps. v14 has long caused problems for most users.
