mcrs969
May 10, 2021Luminary
RBR750 and VLAN ID 835 with no PPPoE
Hi community, I'm a very happy Orbi RBk752 User and I recently extended my Armor subscription by buying a 12 months plan. I really think the RBk 752 is a wonderful product, capable of great perfo...
- Sep 07, 2021
Dear All,
sorry to keep you all waiting. But I confirm that setting VLAN 835 as reported works on Orbi RBR750 with my Fiber connection.
So I can get an IP in IPoE configuration and the traffic can be under VLAN 835 as per my ISP requirements. All of this can be simply made by the VLAN settings in the advanced configurations by modifying the existing one.
May 10, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
- mcrs969May 10, 2021Luminary
Thanks FURRYe38, I immediately reported my post to the Mods because I noticed after having posted that an Orbi (AX) section is available, I hope they can move the thread there otherwise I'll post again.
Thanks for the info, I have also read some topic but never found a detailed relation between VLAN and how the connection is negotiated.
