mcrs969
May 10, 2021Luminary
RBR750 and VLAN ID 835 with no PPPoE
Hi community, I'm a very happy Orbi RBk752 User and I recently extended my Armor subscription by buying a 12 months plan. I really think the RBk 752 is a wonderful product, capable of great perfo...
- Sep 07, 2021
Dear All,
sorry to keep you all waiting. But I confirm that setting VLAN 835 as reported works on Orbi RBR750 with my Fiber connection.
So I can get an IP in IPoE configuration and the traffic can be under VLAN 835 as per my ISP requirements. All of this can be simply made by the VLAN settings in the advanced configurations by modifying the existing one.
CrimpOn
May 10, 2021Guru - Experienced User
mcrs969 wrote:I'm not sure if Orbi RBR 750 allows the VLAN ID along with the IPoE and not with the PPPoE.
Can somebody tell me if VLAN ID works also with no PPPoE connections?
VLAN ID on the Orbi appears to be independent of ISP connection type (PPPoE, IPoE, DHCP).
Page 76 of the User Manual discusses VLAN ID in the context of IP television, not IP address.
https://www.downloads.netgear.com/files/GDC/RBK752/RBK752_UM_EN.pdf
In addition to posting in the "AX" community forum, it might help prompt a response if you identify the new ISP.
(In hopes that an Orbi owner has successfully connected to this ISP already.)
Some ISP technical support is more sophisticated than others and may have information specific to Orbi routers.
