mcrs969
May 10, 2021Luminary
RBR750 and VLAN ID 835 with no PPPoE
Hi community, I'm a very happy Orbi RBk752 User and I recently extended my Armor subscription by buying a 12 months plan. I really think the RBk 752 is a wonderful product, capable of great perfo...
- Sep 07, 2021
Dear All,
sorry to keep you all waiting. But I confirm that setting VLAN 835 as reported works on Orbi RBR750 with my Fiber connection.
So I can get an IP in IPoE configuration and the traffic can be under VLAN 835 as per my ISP requirements. All of this can be simply made by the VLAN settings in the advanced configurations by modifying the existing one.
mcrs969
May 18, 2021Luminary
thank you CrimpOn for the advice, I am happy to see NETGEAR moderators moved the thread in right section, sorry for my mistake.
The ISP is Pianeta Fibra, a small but very high quality italian ISP delivering 1000/300 Mbps over FTTH and their only requirement is:
dynamic obtain of IP from ISP
VLAN 835 on WAN
I'm still not sure if this is supported, by checking manual there're several examples on Television, but the guide in the advanced page of RBK75x GUI seems to be ok also for connectivity of WAN traffic.
I have of course other devices to try but I'd love if the RBK75x supports it. Anyone who had experience in connecting the ONT to Orbi and enabling VLAN 835 (or any other number) to get the wan traffic?
Soon I'll be migrated to this ISP so I'll also be able to share a practical test ;)
May 24, 2021Guru - Experienced User
Any progress on this?
VLAN 835 on WAN
- mcrs969May 25, 2021Luminary
hello FURRYe38 ,
thanks for asking.
Basically -> it works/worked, enabled DHCP (that's how I get my IP connection as ISP has S-VLAN and C-VLAN per every Customer so each Customer is univocally identified at their BRAS/gateway by these two combinations) and enabled 835 by ticking the flag "enable" on VLAN and selecting Internet, modify 10 (default value) to 835 and it worked straight away.
But please wait to get this answer like "confirmed" as I'd like to double check couple of things before stating it with confidence :D
Michele
- FURRYe38May 25, 2021Guru - Experienced User
Let us know how it turns out.
- mcrs969Sep 07, 2021Luminary
Dear All,
