mcrs969
May 10, 2021Luminary
RBR750 and VLAN ID 835 with no PPPoE
Hi community, I'm a very happy Orbi RBk752 User and I recently extended my Armor subscription by buying a 12 months plan. I really think the RBk 752 is a wonderful product, capable of great perfo...
- Sep 07, 2021
Dear All,
sorry to keep you all waiting. But I confirm that setting VLAN 835 as reported works on Orbi RBR750 with my Fiber connection.
So I can get an IP in IPoE configuration and the traffic can be under VLAN 835 as per my ISP requirements. All of this can be simply made by the VLAN settings in the advanced configurations by modifying the existing one.
May 25, 2021Guru - Experienced User
Let us know how it turns out.
mcrs969
Sep 07, 2021Luminary
Dear All,
- FURRYe38Sep 07, 2021Guru - Experienced User
Glad is working for you.
Please mark your thread as solved so others will know.
Enjoy.- mcrs969Sep 07, 2021Luminary
Thanks for the hint, while regarding the "backup configuration" I prefer to keep all data logged in a file and set back all parameters by myself... :) little old method (for sure less efficient and more time consuming) to re-work configurations and re-think them over the time. I do this at every FW update on devices with manual FW update. :)
Thanks anyways also for the link!
:smileywink:
