NetCrashNG's avatar
Apr 27, 2022
RBR750 CONNECTION_REFUSED loading admin interface
I just updated to the latest frimware RBR750-V4.6.8.2 and after everything came back... 192.168.1.1 actively refuses to connect (ERR_CONNECTION_REFUSED).
  • I did a reset on the router (pin for 7seconds etc) and re-configured everything, and I'm back to normal.
    After the reset, the router web interface answered immediately.
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
      • FURRYe38's avatar
        Be sure to clear out all browser caches...
        What browser are you using? Same thing happens with a different browser?
        Are you wired or wireless connected to the RBR?
        Happens on other PCs as well?
