Charlie53463's avatar
Charlie53463
RBR750 repeatedly losing wifi connection
This looks like a common problem, not happy given how much i've paid... trying to decide whether to return as faulty.
Firmware: v4.6.14.3
SSID: unique name.  Same name across all bands.
Locations: three routers connected by Cat6 ethernet, separated by 25m.
Modem: standard UK Virgin hub in modem mode.
Restarted: followed proper switch-off and cycling in correct order... and since firmware updated.
Devices tried: iPhone12, iPhone13, Android S20.  Sames issue across all three phones.
Problem: wifi connection drops, and will not re-connect. Appears to occur when moving around - i.e. a mesh issue? Have to switch off wifi and wait, then switch back on - that usually fixes, but it can take a few goes.
Ethernet: appears to work fine.
Virgin media internet connectivity tracker: using a tracker website shows no drop-outs to the modem.
Have not tried a full factory reset - the router is new and don't expect to have this level of manual intervention.  I've switched from a dd-wrt router set-up simply because i don't have time to tinker these days.
2.4 Wireless settings:
Channel: 8 (checked for conflicts)
Region: Europe
Enable 20/40 MHz coexistence = Enabled
Enable WMM = Enabled
CTS/RTS Threshold = 64
Preamble Mode = Short preamble
Transmit power control = 100%
5GHz Wireless settings:
Channel: 52 (checked for conflicts)
CTS/RTS threshold = 64
Preamble mode = Short preamble
Security WPA2-PSK[AES]. No VLAN or bridges.  No Static routes.  No IP6.  VPN enabled, but not used often.  Access control turned off.
  • FURRYe38's avatar
    Are the RBS ethernet connect to the back of the RBR or is there a LAN switch in between? If so, brand and model please.
    Be sure to disable any WiFi Private IP Address features on the Apple devices while at home:
    https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
    Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Try setting 40Mhz only on the RBR.
    Try changing CTS to 500 and see.
    • Charlie53463's avatar
      Charlie53463
      Hi thanks for replying 🙂
      I did have a TP link 5 port gigabit unmanaged switch (TL-SG105S) in between one of the satellites... so i've removed this now.  So both satellites are directly connected via Cat6.
      Yes wifi private IP/mac is disabled on the iPhones...
      Have made those changes you suggested... will let you know if it makes a difference.
      House is about 1900sq ft.
