Toppingphoto
Nov 18, 2024Aspirant
RBR750 wired connection is slower than wifi
I don't understand what is going on. I have spectrum internet and the download speed test going into my router is 490 - 500mbps. The wifi connection on my phone - laptop - and iMac is around 400mbps. However anything I plug into the router gets less than 100mbps, sometimes as low as 20mpbs. I have tried different cables, different computers and did a firmware update confirmation. Is this an issue with older Orbi products? Mine is a little over 2 years old.
No. This is not an issue with "older Orbi products". Users who subscribe to gigabit ISP service regularly report download speeds of 900+ megabits/second. (It is physically impossible to achieve a full gigabit because there is overhead inherent in Ethernet transmission which consumes a portion of the theoretical bandwidth.)
Changing cables and trying different computers are the two steps typically recommended. (also changing which Ethernet port is being used).
It sounds like the reported speed is not consistent for a specific computer. Is that what is being observed?
- ToppingphotoAspirant
No the problem is consistent with each computer I try. Anything done wireless is fat around 400mbps. and anything done wired is less than 95mbps. I even tried hooking direct out of the orbi without a switch or anything to interfere. That method got me the 95mbps. Seems like an output problem with the orbi
Check with a different wired PC to see if same thing happens.
Check the connect rate on the PC and on the RBRs web page under Advanced/Show Stats tab to see if the connection rate on the LAN port on the RBR shows 100Mpbs or 1000Mpbs. Should be 1000Mbps.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
